misfire 5.4 2002 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 1 (permalink) Old 07-19-2012, 08:55 PM Thread Starter
Send a message via MSN to martinp
Question misfire 5.4 2002
hi i have a misfire on my truck with no code. i had change spark plug for dealer model and 8 coils on plug. and my idle is 550- 600 rpm. hard acceleration is ok,but at 100 km/h steady is buck. ( 1400 to 2200 rpm) compression is ok (min 120 psi and max 150 psi at cold) vacuum leak? i remove my cat for sure is not clogged.
tanks for your help
martin
martinp is offline
NEED HELP: Misfire? Sounds like Exhaust leak.... SCrew Lariat F-150 2004 to 2008 Forum 4 05-30-2012 02:26 PM
2002 F150 4.6L Haley-Special F-150 1997 to 2003 /04 Heritage Forum 2 02-26-2010 03:03 PM
2002 F-150 White_Snake F-150 1997 to 2003 /04 Heritage Forum 7 02-19-2010 07:35 AM
NEED HELP: timing? misfire issue? Hammermill97 F-150 2004 to 2008 Forum 6 09-25-2009 10:39 PM
strange miss...low grade misfire of TCC? dalman Driveline and Transmission 0 02-18-2008 06:20 PM
