Question - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 12 (permalink) Old 01-15-2013, 08:24 PM Thread Starter
Question
Hello Everyone,
I have a question that I am hoping someone can help me with. I have a 1979 Ford F250 with a 460 J-Type engine.
Recently the heater has become intermittent. I removed the old thermostat and replaced it with a new one. I checked the old one (180 degree) and it was still good but replaced it with a new one (190 degree) anyway.
The new thermostat did not correct the problem. I thought it might be the heater core, but nobody seems to think that a heater core can be intermittent.
The truck warms up nicely, no overtemp issues, the coolant level is good. To compond the confusion, In the morning I start the truck and after about 10 minutes, it blows warm air. As soon as I put it in drive, nothing but cold. If I put it in park, it may blow warm, it may blow cold.
My brain has me thinking it could be a vacuum issue. I am going to change the heater core regardless but thought you guys might have some good ideas for me.
thanks
BlueDevil is offline
post #2 of 12 (permalink) Old 01-15-2013, 08:35 PM
I like Fords Too's Avatar
does your truck also have air conditioning ?
if so perhaps there is an issue with the water valve on the heater hoses that turns off the hot water flow when useing the a/c
or maybe your getting an air bubble that stops the flow of heat when it forms ?
I think my 76 water valve was cable controled (maybe) but if your's has a vacume diafram on it maybe the vac hose got routed wrong somehow
I like Fords Too is offline
post #3 of 12 (permalink) Old 01-15-2013, 08:40 PM Thread Starter
No it does not have air conditioning. Can you purge a line to check for air bubbles? I am not exactly sure how they would form, because there are no leaks that I can see.
post #4 of 12 (permalink) Old 01-15-2013, 10:13 PM
happened to me on a Ford Ranchero I had. Let the engine warm up and hit the throttle under the hood, see if your upper rad hose is collapsing under throttle
post #5 of 12 (permalink) Old 01-16-2013, 10:03 AM
Manford's Avatar
I would bleed the heater core to start out with and just make sure you are not getting an air lock in the heater core. It can happen when the revs change the fluid flow velocity in the lines. Simple to do, take the lower hose off or even better yet get the bleeder kit from one of the parts stores, and run the vehicle till you get good flow through the core. Replace into the rad what ever you drained out while running and see if that fixes your issue.
__________
ManFord
Manford is offline
post #6 of 12 (permalink) Old 01-16-2013, 12:33 PM
knowing these trucks didn't come with coolant recovery bottles for the rad to spit into , maybe it's sucked enough air back into the system to trap a bubble in it somewhere
when my 79 goes back together I intend to add a recovery bottle / can to mine - maybe it's a good idea to think about adding one to your's too
might be an idea to try hooking the garden hose up to each tube of the core , one side at a time to see if you can flush any crud out of the core that may be blocking the small tubes inside it - if there is a large chunk of scale floating loose in the tank on the hearter core it could be blocking it off internally - though I'd still bet my dollar on an air bubble first
post #7 of 12 (permalink) Old 01-16-2013, 01:11 PM Thread Starter
thanks for the suggestions guys. I will give them a shot before changing out the heater core altogether and report back.
post #8 of 12 (permalink) Old 01-16-2013, 02:14 PM
Manford's Avatar
yep, for sure, you would have to do this anyway if you install a new hearter core.
__________
ManFord
Manford is offline
post #9 of 12 (permalink) Old 01-16-2013, 06:13 PM
How large is the radiator? How many blades on the fan? Is it a clutch fan?
post #10 of 12 (permalink) Old 01-31-2013, 09:44 PM Thread Starter
update - I did pretty much everything you could possible do to correct this problem and nothing worked. I was in a parking lot and had the hood up looking and trying to see what I was missing when this old timer came over to admire the truck. He asked what the problem was and after telling him, he takes one look and says, "one of your hoses is too long" and it hit me like a ton of bricks, the longer hose created a 'p - trap'...problem solved.
Question Denis254 Audio and Electronics 1 04-11-2009 01:33 AM
Question Denis254 Ranger Forum 8 12-08-2008 12:37 AM
NEED HELP: Question Denis254 Ranger Forum 5 11-16-2008 12:26 AM
