Just an FYI - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 07-12-2014, 07:20 PM Thread Starter
Just an FYI
If you own an ecoboost and plan on keeping it a long time, please change your oil more than the recommended 10000km interval. It's not just a ford problem, ANY direct injected engine has fuel squirted in the combustion chamber AFTER the intake valve. All those pesky crankcase vapors ingested via the PCV valve have nothing to clean them off the intake port. Best defense drain old oil before it's dirty. There are car lots full of coked up cylinder heads showing at dealers all over the place with drivability issues.
05 F150 Lariat Screw.
89 LX5.0 usual mods.
ronburgundy is offline
post #2 of 2 (permalink) Old 08-29-2014, 08:25 PM
The advice to change oil frequently is solid. Not too sure about the carboned up intake valves though. If anything, it's the 5.0 that has issues there. Its valves wear paper thin until such a point that the holes (usually 4 and 8) drop compression.
I know VW/Audi/Lamborghini has had major growing pains with direct injection. The lack of fuel spray over the valves prevents the back of the valves from getting washed. All the same, I've yet to see a 3.5 GTDI come in with coked up heads. Why Ford is avoiding this across all of its direct injection motors is beyond me.
Common 3.5 ecoboost issues include
- defective turbochargers (most often the wastegates seize, but once in a while the impeller wheels poop the bed)
- building oil (high pressure fuel pump, but if you ask Ford it needs a PCM reflash and a new block heater)
- catalysts (see, building oil)
- turbocharger control solenoid (P0234 overboost code)
- carbon tracking on the spark plugs (change the plugs every 50 000 - 60k)
- faulty primary and secondary timing chain tensioners and stretched chains (runs like a dog, P0011/12, P0021/22 cam and crank out of relation)
Varsity Tyler is offline
FYI...For 2014 F -150 owners... Fordsforever6.0 F-150 2009 to 2014 Forum 4 06-27-2014 08:17 PM
Hey James...FYI Fordsforever6.0 Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 5 12-04-2013 06:21 PM
fyi 6.0l owners shelbyx1 Super Duty Forum 17 03-15-2009 10:55 PM
