P-0305 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 13 (permalink) Old 03-12-2008, 11:37 AM Thread Starter
Angry P-0305
Here we go AGAIN now it's telling me a misfire on #5,So I guess I'm off work again,3rd time in a month.I guess I'm pullin out #5 to see if it is on it's way out.Like #7 did 3 week's ago.
MRGADGET is offline
post #2 of 13 (permalink) Old 03-12-2008, 02:09 PM Thread Starter
Went and got 7 New spark plugs,May as well replace the other 7 to be safe.
MRGADGET is offline
post #3 of 13 (permalink) Old 03-13-2008, 12:20 AM
That is horrible
What a luck you have there
4D Tough is offline
post #4 of 13 (permalink) Old 10-18-2008, 01:05 PM
saleen's Avatar
How did you make out MRGADGET? I am very interested in this thread because my 04 F-150 came up with #7 misfire.....I changed the coil pack. Seemed ok for a day then the same shudder. I checked the codes now I have #5 misfire just like you.
p.s. I am going to send ya a pm just incase you don't see this because of the age of the thread.
saleen is offline
post #5 of 13 (permalink) Old 10-18-2008, 01:35 PM
Not sure if he comes on here anymore, but I'm sure someone with the knowlege will post up. Good luck.
post #6 of 13 (permalink) Old 10-18-2008, 01:42 PM
saleen's Avatar
Thanks Fordwheller......just wanted to make sure I am not missing something and start replacing all these coil packs when it could be something else.
saleen is offline
post #7 of 13 (permalink) Old 10-18-2008, 02:02 PM
Try swapping you new #7 cop for your misfiring #5 cop and see if the code changes cylinders
post #8 of 13 (permalink) Old 10-18-2008, 02:44 PM
PM shelbybx1
post #9 of 13 (permalink) Old 10-19-2008, 10:22 PM
saleen's Avatar
Thanks for all the info guys.....The plugs were replaced only about 2k ago. I have decided to not replace anymore ford coils. I ordered a complete set of 8 40,000 volt Accel coils. I should have them in a few days and will report back.
saleen is offline
post #10 of 13 (permalink) Old 10-19-2008, 11:45 PM
hi saleen:did you check #5 for moisture build up,is a common concern from leaking therm housing gasket?
