Oil, with murky appearance - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 15 (permalink) Old 03-18-2008, 01:07 PM Thread Starter
nf150's Avatar
Question Oil, with murky appearance
So today I top up the oil, I am due for a change but haven't had the time, only 400km over. anyway the issue...is;
I take the oil filler cap off and to my surprise there is a residue with an oily amber/white appearance at the top.
Any Idea what this may be...
I drove for a bit after topping the oil and checked the filler cap and neck again and none of this was there...
The truck seems to drive fine, and has not been idling rough, or anything, no blue smk out the back...
Anyone with suggestions please let me know.
nf150 is offline
post #2 of 15 (permalink) Old 03-18-2008, 01:29 PM
you may have coolant in your motor oil caused by a leaking head gasket,intake manifold gasket,cracked or warped cylinder head or engine block.definetly a job for your favorite mechanic. a compression test on all cylinders should tell them whats wrong
Dazed is offline
post #3 of 15 (permalink) Old 03-18-2008, 01:31 PM Thread Starter
nf150's Avatar
thanks will do...if there is no re-appearance of this after the oil change do you think there is an issue????
nf150 is offline
post #4 of 15 (permalink) Old 03-18-2008, 01:42 PM
Coruptyed's Avatar
even if there isnt its all ways safe to make sure there is nothing wrong so it doesnt happen again or possibly get worse. I would suggest getting it looked at either way.
The F150 UFO
Coruptyed is offline
post #5 of 15 (permalink) Old 03-18-2008, 02:12 PM
Don't worry it's just condensation most likely caused by too many short trips and the engine not heating up enough to go though a full heat cycle
post #6 of 15 (permalink) Old 03-18-2008, 03:35 PM
Agree with skrwz on that
when you drain the oil have a look if is milky if it is then yes you have a coolant leak if not its just a condensation
keep us posted
post #7 of 15 (permalink) Old 03-18-2008, 04:47 PM
agreed. good call guys.
Dazed is offline
post #8 of 15 (permalink) Old 03-18-2008, 09:02 PM
also while its running pop the rad cap off if you see bubbles problems there to...
sounds like moisture tho... if your oil on the dipstick isnt white/milky i wouldnt worry about it
post #9 of 15 (permalink) Old 03-19-2008, 12:29 AM
Make sure your Rad is cold before you do this, we don't want anyone get burn, as will be under pressure when is hot
post #10 of 15 (permalink) Old 03-19-2008, 07:15 AM Thread Starter
nf150's Avatar
thanks for all the help, there is no bubbles in the rad reservoir...and the dipstick just has golden oil on it...I never thought about the short trips up the hill to work, it is only an 8 minute drive...moisture would build up...
thanks again!!
nf150 is offline
Oil changes, who does them and who gets them done? fordtough.ca Truck/SUV Talk 97 11-22-2013 02:47 PM
What Oil? fordtough.ca Gas Engines 28 03-14-2010 09:01 PM
What engine oil do you use and When? fordtough.ca Truck/SUV Talk 10 08-15-2008 08:18 PM
What oil do you use? Smokefan Gas Engines 23 02-18-2008 07:53 PM
