low vacuum - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 03-19-2008, 10:36 PM Thread Starter
low vacuum
anybody know what could cause low vacuum and very rich mixture in a 5.8 efi...compression is great
nnik is offline
post #2 of 11 (permalink) Old 03-20-2008, 12:34 AM
for low vac.. my first guess would be a leak in one of the vac. hoses. check them for cracks. some may be hard to get too. I thnk if you spray carb cleaner or something similar on the hoses and if the rpms go up then you found the leak. Not sure if it carb cleaner or brake cleaner, maybe someone can chime in on that. For running rich..my first step would be to clean the MAF in case its dirty and sending the wrong info.
post #3 of 11 (permalink) Old 03-20-2008, 10:27 AM Thread Starter
thanks checked hoses..no change, truck is sd so no maf
nnik is offline
post #4 of 11 (permalink) Old 03-20-2008, 11:18 AM
Carb cleaner.Sounds more to me like plugged vacum lines,,,a vac leak would give you lean codes?
4x4.0 is offline
post #5 of 11 (permalink) Old 03-20-2008, 12:26 PM
I agree, check for a vacuum leak again pinched hose etc. or vacuum cap missing also check for a clogged PCV valve or hose after that try hooking up a vacuum Gage to the truck and go from there
post #6 of 11 (permalink) Old 03-20-2008, 01:08 PM Thread Starter
no codes, unplugging vacuum to brake booster actually causes idle to smooth out and go up(probably due to rich cond. caused by vac. leak which is hard to find b/c spraying carb. cleaner or wd 40 will not work...the mixture is rich already) vacuum stays the same. no pinched hoses , ECT,ACT have been replaced can the IAC cause this..........?
nnik is offline
post #7 of 11 (permalink) Old 03-21-2008, 02:06 AM
I think a clogged or stuck pcv can
post #8 of 11 (permalink) Old 03-21-2008, 12:10 PM Thread Starter
thats new too
nnik is offline
post #9 of 11 (permalink) Old 03-21-2008, 08:39 PM Thread Starter
figured it out, engine just won't hold compression dry test 105-125psi leaks down to nothing in about 10 sec, wet test 150psi leaks down in about 15sec...causes map to do funny things, so I pulled the pos and I'll put in another
nnik is offline
post #10 of 11 (permalink) Old 03-22-2008, 12:58 AM
glad you got it figured out.
Show us How Low did you go............. fordtough.ca Street Scene 39 03-01-2012 03:12 PM
Low Pricing for Lightning? Fordsy SVT Lightning 22 12-17-2008 11:05 PM
Low dust brake pads, what should I get ??? fordtough.ca Wheels and Tires 36 05-07-2008 08:59 PM
low beams/highbeams and foglights not working myneedforspeed Lighting 0 12-18-2007 11:32 PM
