P-o351 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 03-20-2008, 02:01 AM Thread Starter
Exclamation P-o351
It say's it's a Ignition coil A Primary/Secondary Malfunktion.
So if I replace the coil on #1 spark plug then that should clear the engine light, right?
That is the only code it showed me twice so that's primaty and secoundary so just replace it?
Owe and it's not my truck for a change...lol
It's an econoline van with a 5.4ltr.
MRGADGET is offline
post #2 of 3 (permalink) Old 03-20-2008, 02:18 AM
Ill try to figure more later but heres a quick rundown for you
__________________________________________________ _____
Possible causes:
-- Open or short in Ign Start/Run circuit.
-- Open CD-1 or CD-2 circuit in harness.
-- CD-1 or CD-2 shorted to ground in harness.
-- Damaged coil pack (coil)
-- Damaged PCM.
post #3 of 3 (permalink) Old 03-25-2008, 08:58 PM Thread Starter
Thanks for the info.Gonna start with the coil pack.
MRGADGET is offline
