Misfire/bucking at idle and driving speeds - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 07-09-2017, 09:14 AM Thread Starter
Hello
Im new on here so bare with me!
Im sure you heard this before, but im having issues with my truck misfiring/bucking at idle and while driving. Its an 05 lariat with the 5.4. With 125,000 km. I have had it to 4 different garages and nobody can figure it out. Ive had the issue for over a year and its driving me nuts! No codes ever pop up. 1 time i finally had the engine light come on and it was a code p306. I changed the cop and the plug on that cylinder, and as soon as i drove it there was no change whatsoever. Ive change 2 more coils and plugs on cylinders 2 and 5 like the garage said with no change. I have tried moving a new coil around, no luck. Changed fuel filter twice in 2 momths because the original one was very dirty, and they are only 25.00 so why not! Had a buddy scan it and reset the computer this weekend no codes, still same problem but my gas mileage went from 22.3/100km to 17/100km on hwy but still misfired. Misfres at low amd high rpm. Sometimes it feels like its only running on 6 cyliders, no power bit only for couple senconds and goes away. Misfire is intermittent. Ive changed the driver control module. Changed all plugs over a year ago (never even broke 1)fuel injector cleaning, maf sensor cleaned, ive tried everything i can think of and still not any better or any worse. Thinking of throwing new plugs in again because i didnt use ford motocraft and ive read that i should have. The plugs in it now all look fine. Ive been told it could be the tuner. Unfortunately same prick stole it out of my truck so i cant even put it back to factory��. I need help! Thanks
Webster82 is offline
post #2 of 6 (permalink) Old 07-09-2017, 06:52 PM
So many things to check. What is fuel pressure and volume like? Is there a sock type filter on the pump that is partially collapsing? VCT solinoid or phaser going bad.
post #3 of 6 (permalink) Old 07-10-2017, 06:40 AM
Try running some 94 octane through it and see how it runs. You had said it had a tuner. It may be stuck on running something other than pump gas. Air filter clogged, cat melted down and clogged? Not everything sets a code. Some mechanical issues won't.
post #4 of 6 (permalink) Old 07-14-2017, 08:06 AM Thread Starter
I had tried runnimg 94 octane in it and i will say it ram a bit better, but still has what seems like a misfire. Ive had the tuner in it for approx 3 years and never had issues intil about a year ago. Its never gotten worse or any better. I saw a post about the vct's and it said to shock them with 12 volts from the battery. So i thought what the heck! When i did it at first i heard no clicking or anything. After a couple times they started to click, which seemed to possibly free them up?! I dunno. I drove it and never really made a difference. Ill have to check the fuel pressure and see what it is. How do i know if my cats are pooched? I hear a popping noise in the exhaust at idle and i Have soot on the tailpipes. Just tired of taking it to the garage and getting hosed! As far as the cam phasers. It doesnt sound like a diesel but when I listen at the fromt of the valve cover with a screwdriver to my ear, the drivers side appears to sound different than the passenger side. Drivers is almost like a grimding noise. The fuel pump id have to drop the tank and check if there is a sock on it. I hear a loud ticking or knock at the bottom end when it warms up. Maybe time for a trade in lol i love the truck tho. Only has 125000 on her and its very clean. Tha ks for your replies. Ill do some more hunting and see what i find
post #5 of 6 (permalink) Old 07-14-2017, 04:11 PM
Disconnect the pipes fro the manifold and see how it runs. If it seems less constipated, then further investigation is required. Clogged cats should set codes though.
post #6 of 6 (permalink) Old 07-15-2017, 03:35 PM
Ticking in bottom end when warm could be chain tensioner seals leaking or worn tensioners causing chain slap. If seals are bad oil pressure test should tell you.
Misfire on 7 & 8 herbz F-150 2004 to 2008 Forum 8 06-23-2016 08:12 PM
misfire 5.4 2002 martinp Gas Engines 0 07-19-2012 08:55 PM
NEED HELP: Misfire? Sounds like Exhaust leak.... SCrew Lariat F-150 2004 to 2008 Forum 4 05-30-2012 02:26 PM
NEED HELP: timing? misfire issue? Hammermill97 F-150 2004 to 2008 Forum 6 09-25-2009 10:39 PM
