how does weather affect a/f ratio? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 05-08-2008, 08:21 AM Thread Starter
lightning25's Avatar
Send a message via MSN to lightning25
I plan on going racing this friday and its supposed to be about 55 degrees out, at mid day.
I am running 11.6 a/f ratio when i was tuned at about 80-85 degrees.
What affect will that cold temp have on my a/f ratio? will i lean out and have issues?
Sean
I'm canadian, eh!
2001 Ford Lightning
13.1 - 1/4 @ 105mph
lightning25 is offline
post #2 of 4 (permalink) Old 05-08-2008, 08:29 AM
Biz
Biz's Avatar
It shouldn't matter that much. On a colder day the A/F will tend to be on the lean side, but it shouldnt be enough to be an issue. You will make some good power.
Biz is offline
post #3 of 4 (permalink) Old 05-08-2008, 11:32 AM Thread Starter
i hope i make good power!!!
at 80-85 degrees (what i was tuned at) the MAF showed 880 counts. i have an SCT 2600 on and the max is 1023. so i have a few hundred counts to play with.
i jsut dont want to end up leaning right out. i was set up for 11.6 a/f when i was tuned, at the same 80-85 degrees. and i do have a meter, so i can keep an eye on it and i will be datalogging so i can tell if the engine is pulling timing.
I'm canadian, eh!
2001 Ford Lightning
13.1 - 1/4 @ 105mph
post #4 of 4 (permalink) Old 05-08-2008, 12:44 PM
Biz
Biz's Avatar
you still have a decent amount of a/f to go before the truck will lean right out. There's a few different factors to come into place. Humidity, sea level here compared to there. Do the data logging (real time) and keep an eye on it. I dont see you having a problem though.
Biz is offline
