turbos - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 05-17-2008, 08:45 PM Thread Starter
turbos
so i just sold my lightning, i'm 90% sure i'm buying a lincoln ls with the 3.9L v8, i'm thinking i'll be installing an sts turbo, probably 10-14psi boost, can anyone tell me if i'll need to upgrade injectors, also for a daily driver do i have anything to gain from running twin turbos?
thanks
flip_86 is offline
post #2 of 5 (permalink) Old 05-17-2008, 10:55 PM
Spinal's Avatar
Send a message via AIM to Spinal Send a message via MSN to Spinal
well from what i've read upgrading injectors is probably a good idea, i mean if the engines not designed running with boost, everything should be accounted for when converting. as for twin turbo setup, not too sure about that one, but i don't see any point in it considering it'll be a DD, you probably wouldn't use their full potential.
Spinal is offline
post #3 of 5 (permalink) Old 05-18-2008, 03:41 AM
You might also have to upgrade the fuel pump, with bigger injectors pumping more fuel in you migh need a stronger pump to keep up.
post #4 of 5 (permalink) Old 05-18-2008, 07:45 AM
kenne bell makes the Boost a Pump... cranks it up when you need the fuel and uses stock pump from what ive read on the boards it works great
theres a boosted page (for turbo's) cant really think of the name but theyd be the guys to ask about turbo's
post #5 of 5 (permalink) Old 05-20-2008, 03:00 PM
Colin's Avatar
I don't think the 3.9L will handle 14 pounds of boost. It will take probably 8 pounds tops unless you build the motor. For a daily driver you would want one small turbo or 2 really small turbos. The plumbing will be a nightmare with 2 turbos though.
You would also need a blowthrough MAF (for ease of tuning), matched injectors for the power you are making, new fuel pump, custom exhaust work, a fuel pressure regulator and a custom tune of some sort to make everything work.
Colin is offline
