Engine tuneup....... - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 07-31-2008, 08:55 PM Thread Starter
Other than fuel filter, plugs and coils what else
Have you done one, and what did you do?
post #2 of 4 (permalink) Old 08-21-2008, 01:12 AM
Done all the above except never a coil (never neded a change, knock on wood) never done plugs on mine yet, scares me that i'll break one and doubtful any shop here will have the tool. my older pickups ( pre 97's) were sooo much easier to do the above. i'll attempt most things.
post #3 of 4 (permalink) Old 03-14-2010, 09:21 PM
Plugs, wires, dist. cap, rotor, air filter, pcv valve and filter, oil and filter, grease, starter bolts, fluid levels, check brake pads, shoes, drums and rotors, check a few other points on the truck, tightening up bolts and such. I make a day of it.
post #4 of 4 (permalink) Old 03-14-2010, 10:10 PM
built a 5.O H.O and then did a swap from 4.9 to 5.O incuding all wiring
Engine cleaning truckpilot Care & Detailing 19 04-08-2011 04:04 PM
NEED HELP: Engine swap???? spittingcobras Gas Engines 11 03-08-2010 12:32 AM
What engine oil do you use and When? fordtough.ca Truck/SUV Talk 10 08-15-2008 08:18 PM
Engine code blueghost F-150 2004 to 2008 Forum 3 05-22-2008 12:42 PM
Ranger Engine? fordtough.ca Ranger Forum 13 03-16-2008 07:40 PM
