F150 4.9 cylinder 2 missfire. please help!! - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 14 (permalink) Old 09-12-2008, 09:30 PM Thread Starter
Angry F150 4.9 cylinder 2 missfire. please help!!
Hello i have a 1994 f150 4.9 straight 6 engine. cylinder 2 has a spark and fuel but wont fire at all. here is a list of the things ive done
compression test = ok 110psi+
new rotor
new cap
tuned ignition timing
new plugs
swapped leads round but problem stayed in cylider 2
swapped injectors round but problem stayed with cyl 2 and checked power
removed rocker cover and checked push rods were working and nothing broken
had the error codes read and it came up with "spout connector open curcuit". been told that error is there because of the missfire.
does anyone know if theres anything electonic or mechanical ive missed that would cause this?
apprectiate any help
thanks
gdowle is offline
post #2 of 14 (permalink) Old 09-12-2008, 09:52 PM
check for crossfire between your plug wires
post #3 of 14 (permalink) Old 09-12-2008, 10:31 PM Thread Starter
whats that mean?
gdowle is offline
post #4 of 14 (permalink) Old 09-12-2008, 10:48 PM
Did you change Plug Wires?
If not you may have leakage between 2 wires
post #5 of 14 (permalink) Old 09-12-2008, 11:41 PM
crossfire is when your current jumps from wire to wire or another point. Best way to check is at night.
post #6 of 14 (permalink) Old 09-17-2008, 09:51 PM Thread Starter
nope no crossfire.
im thinking its got to be electrical but not sure what other than the coil. i think that would make it run rough on all cylinders wouldnt it?
gdowle is offline
post #7 of 14 (permalink) Old 09-17-2008, 11:20 PM
How is the spark on the cylinders 1 and 3 in compressing to #2 check it at night and look for colour (White or yellow)and intensity
post #8 of 14 (permalink) Old 09-18-2008, 12:47 AM
post #9 of 14 (permalink) Old 09-18-2008, 02:10 AM Thread Starter
the scanner says its running rich but id imagine its because #2 not firing. i swapped injectors round and checked wiring with a flashing led tester.
what do you think would make 1 plug fire at the wromg time?
gdowle is offline
post #10 of 14 (permalink) Old 09-18-2008, 03:39 AM
try resetting the ECU
R.I.P F150... Denis254 F-150 2004 to 2008 Forum 13 04-23-2009 02:21 PM
2004 F150 kwy290 New Members Introductions 11 02-06-2008 11:20 AM
F150 Hesittates speedy69 Gas Engines 4 01-02-2008 04:18 PM
Which F150 to buy? Canadian GP F-150 2004 to 2008 Forum 12 12-31-2007 05:27 PM
