1981 Ford F150 5.0l rebuild - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 16 (permalink) Old 10-21-2008, 03:36 PM Thread Starter
Hey guys, I moved up to ft st John to find greener pastures and in doing so I found my new truck. Its a 1981 ford f150 ranger reg. cab stepside with a 302 on propane. The harmonic balancer has went on it so now im going to rebuild the motor. My spending limit is 2000$ for the motor, can anyone help me with this build? I want a radical cam so I get the rough idle and replace the lifters. An air gap intake and a K&?N Filter. I have to do the bottom end anyways so I was thinking a SCAT crank. Can anyone give me an idea as to what I should be looking for parts wise? Im looking for about 200-250 hp and roughly 250 ft lb of torque.
Jensen is offline
post #2 of 16 (permalink) Old 10-21-2008, 08:00 PM
post #3 of 16 (permalink) Old 10-21-2008, 08:32 PM Thread Starter
Rrriiiiiggggghhhtt. a holley 4 barrel is for gas trucks my young padawan. Mines propane.
Jensen is offline
post #4 of 16 (permalink) Old 10-21-2008, 08:53 PM
tohi2care's Avatar
For you camshaft call Jeff at www.COLTCAMS.com and he can custom make you whatever you need. They are also located in Aldergrove/Langley so he is somewhat local to you.
tohi2care is offline
post #5 of 16 (permalink) Old 10-21-2008, 10:19 PM
sorry meant to say get rid of the propane lol
post #6 of 16 (permalink) Old 10-21-2008, 11:54 PM
why not step up to a 5.8l theres no replacement for displacement.
post #7 of 16 (permalink) Old 10-22-2008, 09:27 AM Thread Starter
Put in a 351M? That would be sweet but would the C-6, propane carb and heads match up?
Jensen is offline
post #8 of 16 (permalink) Old 10-22-2008, 12:12 PM
351 windsor(small block)will match up and you can get alot of perf parts from ford racing like the gt 40 package.vroom vroom!
post #9 of 16 (permalink) Old 10-22-2008, 10:58 PM Thread Starter
the truck has the propane heads. the gt40 heads are nice but I want the truck to be a lower cost sleeper as in under 10,000 dollars for the entire truck
Jensen is offline
post #10 of 16 (permalink) Old 10-23-2008, 01:05 AM
a good eng to start with would be a early 80's 351w ho,and when you rebuild heads get the hardened valve seats bronze guides and swirl valves done.
1998 ford f150 xlt farmerboy3 F-150 1997 to 2003 /04 Heritage Forum 16 07-05-2011 12:38 PM
1997 ford f150 xlt farmerboy3 F-150 1997 to 2003 /04 Heritage Forum 7 02-20-2009 01:52 AM
Should I buy a 2006 Ford F150? Tiki35 F-150 2004 to 2008 Forum 17 10-22-2008 07:33 PM
4.0L rebuild in London not.too.low92 Gas Engines 4 08-20-2008 04:07 PM
