Water in my fuel? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 12-21-2008, 09:15 PM Thread Starter
Water in my fuel?
What do you guys think? I have remote start in my 2008 3.0L and last week when it got really cold, I set my automatic timer to start the truck every three hours for 15 minutes of run-time. It worked fine until the next day.
My truck started and then died. I went out and manually started it, and it ran for about 20 seconds then died. I tried cranking it a few times and it caught once, and again, died after about 20 seconds (when I stepped on the throttle).
I used my other "4x4" for the week and left the Ranger in my driveway. Today I tried manually starting it, and once again it started for about 20 seconds and then died. I tried a few more times but the battery started to drain and no ignition.
My thought is that I have moisture in my fuel. What do you think? Should I purchase a gas-line antifreeze of some type? What is the best one to use?
Thanks for taking the time to read this and I look forward to your suggestions.
Cowboy is offline
post #2 of 7 (permalink) Old 12-21-2008, 09:20 PM
Black Ice's Avatar
Send a message via MSN to Black Ice
I think with all the auto starts it sounds out of gas.
Black Ice is offline
post #3 of 7 (permalink) Old 12-21-2008, 09:31 PM
Doesn't hurt to put Gas Line Antifreeze in at every fill up I put in a full bottle every time I fill the tank(when it's empty) during the winter months.
post #4 of 7 (permalink) Old 12-21-2008, 09:49 PM
post #5 of 7 (permalink) Old 12-22-2008, 06:37 AM Thread Starter
Yes, that thought did cross my mind. Too bad it is not as simple as that. The tank is lower than normal (now at 1/4 tank) and I usually keep it above 1/2.
I will try to get it into the garage to warm up and take it from there.
Cowboy is offline
post #6 of 7 (permalink) Old 12-22-2008, 02:56 PM
in this kind of weather a fuel tank that is constantly below 1/2 tank will build up condensation,it's always a good idea to use gasline a/f.
post #7 of 7 (permalink) Old 03-07-2010, 05:45 PM
Try changing the oil and set your timer for a longer run time. At least smell the oil and see if it smells gas enriched.
Water Leak!! Cooker Ranger Forum 10 11-24-2008 03:02 AM
Water Leak bat052 F-150 2004 to 2008 Forum 2 11-26-2007 07:35 PM
WIFES WATER BROKE... HEAVY METAL British Columbia 16 11-24-2007 09:19 AM
