Inline 6 rebuild - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 16 (permalink) Old 01-12-2009, 01:10 AM Thread Starter
Inline 6 rebuild
With my tax return coming up I was wondering If I should rebuild my Inline 6. When it gets rebuilt I will add a k&n highflow intake throttlebody spacer and redo my exhaust. And for the transmission, that should be done at the same time, I was going to do a stage 1 shift kit and higher torque converter. What am I looking for cost wise at the engine and tranny?
Jensen is offline
post #2 of 16 (permalink) Old 01-12-2009, 03:31 AM
you wanna rebuild the indestructable motor. Why??
post #3 of 16 (permalink) Old 01-12-2009, 06:08 PM Thread Starter
'cause 91 octane in something that has 288k on it does a good job of cleaning the engine. Which means just cause I can afford race fuel doesnt mean I should use it on something that is being held together by oil build up. And an update I just recieved a free Inline 6 engine from a guy at work says it ran when parked last summer and has about 200k on it. So Im trying to find a rebuild kit for the truck but my search has been fairly futile every supplier is in the US.
Jensen is offline
post #4 of 16 (permalink) Old 01-12-2009, 06:37 PM
post #5 of 16 (permalink) Old 01-12-2009, 08:40 PM Thread Starter
Yeah I think it will end up being me and my buddy doing it in a few weekends. I just want a rebuild kit, nothing fancy. I might have to get everything seperate, gasket kit, rocker assy. cam, pistons, rings, seats. ill try napa tomorrow.
Jensen is offline
post #6 of 16 (permalink) Old 01-12-2009, 11:07 PM
that's what I did when I built my 302 that replaced my inline 6
post #7 of 16 (permalink) Old 01-12-2009, 11:10 PM Thread Starter
was your 302 a fi or carbed?
Jensen is offline
post #8 of 16 (permalink) Old 01-12-2009, 11:20 PM
it's injected
post #9 of 16 (permalink) Old 01-13-2009, 12:23 AM
why not just swap in a newer lower mileage motor?? Easier and probably cheaper. Then you can build it up out of the truck.
post #10 of 16 (permalink) Old 01-13-2009, 12:42 AM
when you pull the inline out you will see why it has only one lift hook
1981 Ford F150 5.0l rebuild Jensen Gas Engines 15 10-25-2008 12:23 AM
4.0L rebuild in London not.too.low92 Gas Engines 4 08-20-2008 04:07 PM
