engine lite on 4.0L code po171 &174 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 01-28-2009, 11:48 AM
Pepper
Guest
Posts: n/a
My wifes Explorer (2000) has the engine lite on the codes coming up are PO171 and PO174 meaning lean bank 1 and lean bank 2 .I have cleaned massairflow sensor and tried to check for vaccuum leaks what do I look for ?
post #2 of 3 (permalink) Old 01-28-2009, 02:42 PM
what engine does it have?the 4.0l was notorios for lower intake leaks,is the cold idle pretty fast?
post #3 of 3 (permalink) Old 01-29-2009, 08:20 AM
Chienlaid's Avatar
My 1998 2.5L V6 Contour had the exact same problem and I was getting those exact codes.
Replaced upper and lower intake manifold gasket and voilà!
Chienlaid is offline
Moderation Tools:
Halloween Drive & Drag & TMP - OCT 31 TMPracing Ontario 0 10-07-2008 12:42 PM
MEET/G2G: Ford & Mercury Truck Nationals- August 16th & 17th.08 fordtough.ca Ontario 7 08-06-2008 08:11 AM
Engine code blueghost F-150 2004 to 2008 Forum 3 05-22-2008 12:42 PM
P-0307 Engine Code MRGADGET Gas Engines 14 01-17-2008 12:33 AM
engine code?? silverfox Gas Engines 7 09-12-2007 10:05 PM
