NEED HELP: fan cowling - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 02-07-2009, 05:45 PM Thread Starter
Question fan cowling
Hey guys quick question. If I am trying to remove the fan cowling do I also need to remove the fan as well? Because I tried and it seems like the cowling will not fit around the rotors on the fan.
When removing the fan will I need to use the clutch tool?
Oh, by the way it's a 2005 fx4 with the 5.4l.
albertaboy is offline
post #2 of 5 (permalink) Old 02-07-2009, 07:37 PM
post #3 of 5 (permalink) Old 02-07-2009, 11:23 PM Thread Starter
I think if i get that clutch tool removing the fan would be a lot less complicated and get me closer to my goal of changing the water pump.
post #4 of 5 (permalink) Old 02-08-2009, 12:24 AM
post #5 of 5 (permalink) Old 02-08-2009, 11:16 AM
removing fan makes more sense and will give you the room needed to remove waterpump.
Interior fan speed switch Fordwheeler Interior 4 10-21-2008 10:55 AM
electric fan Jensen Gas Engines 3 07-18-2008 04:56 PM
how do you remove the stock rad fan drive shaft? lightning25 F-150 2004 to 2008 Forum 2 03-16-2008 08:47 PM
