4.6 -4.6 engine swap - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 05-13-2009, 06:46 PM Thread Starter
Has anyone considered or tried swapping a 4.6 out of a stang into their F-150? Im looking at gains. 300 BHP and 320 Lb/Ft torque. And considering the aftermarket availability over the F-150. I would think tis would have been tried already but havent really found anything out about it yet. Dont get me wrong, I aint ripping my engine out tomorrow ar anything but just crossed my mind and looking for a little insight.
littlebronc is offline
post #2 of 11 (permalink) Old 05-13-2009, 08:51 PM
What year of F150 do you want to do this to? I'm sure it would be a lot easier to do in a 04-08 than in a 03 or older. You'd be gaining nearly 70hp and 30ft/lbs of torque. I say if you can do it go for it.
post #3 of 11 (permalink) Old 05-13-2009, 09:39 PM
for the trouble why not just have your motor worked over and get even more HP for the $$ ?
post #4 of 11 (permalink) Old 05-13-2009, 09:52 PM
the stang motor would probably make it's power and torque too high up in the rpm range to make it worthwhile in a truck....the lower the rpm for both is more desirable.
post #5 of 11 (permalink) Old 05-13-2009, 10:06 PM
swapping the cams would fix that
post #6 of 11 (permalink) Old 05-13-2009, 10:18 PM
see...i learned something today once a week ain't bad.
post #7 of 11 (permalink) Old 05-14-2009, 02:58 PM
there is a lot of mods you can do to step up a 4.6 truck engine,would be a lot easier than retrofitting a 3v 4.6 into a 4.6 2v,lots of cams,exh,superchargers,heads,stroker kits availiable.m2c
post #8 of 11 (permalink) Old 05-14-2009, 03:52 PM
like he said lol
also u can drop 3 valve heads on your 2v truck motor.... or even 4 valve if you want... $$ wise theres lots of available 2valves that will do the trick.... i hear trickflow is coming out with a set that flows some sweet numbers (big hp applications) also Patriot Performance makes a good product
post #9 of 11 (permalink) Old 05-20-2009, 10:05 PM
why don't you swap in a 5.4
Duty calls is offline
post #10 of 11 (permalink) Old 05-31-2009, 09:30 PM Thread Starter
lol... oh dont get me wrong, I like my truck just the way it is. I was just thinking about this one day and figured it wouldnt be a bad way to raise the power a little. As taisa899 mentioned, swapping cams would bring the power curves back into a truck worthy range and I have seen a lot of cracked up stangs in the boneyards with engines worth pulling. Like I said, just a mid day ponder, wanted some other opinions on it or to see if it had been done.
NEED HELP: Engine swap???? spittingcobras Gas Engines 11 03-08-2010 12:32 AM
Engine swap? bluegoose Diesel Trucks 5 04-23-2009 02:44 PM
Body Swap! bluegoose Diesel Trucks 3 03-30-2009 02:57 PM
5.4L Supercharger Swap Turbodieselhog Gas Engines 2 02-16-2008 05:45 PM
Swap Meet Smokefan Ontario 7 08-14-2007 08:07 PM
