Synthetic Oil vs Standard Oil - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 17 (permalink) Old 02-08-2007, 04:45 PM Thread Starter
Which one do you think is better
post #2 of 17 (permalink) Old 02-08-2007, 08:08 PM
taisa899
Guest
Posts: n/a
Re: Synthetic Oil vs Standard Oil
Ok then. I just use plain old Castrol 10W30 motor oil. But the again I'm really anal on making sure I change my oil at regular 5000km intervals! :all-good:
Jim
post #3 of 17 (permalink) Old 02-09-2007, 04:39 PM
frddriver
Guest
Posts: n/a
I've been putting fully synthetic in my explorer since i baught it 2 years ago!
for older vehicles i just use plain oil.
post #4 of 17 (permalink) Old 06-01-2007, 11:54 PM
i use royal purpal full synthetic i noticed the difference in the engine response aswell as fuel milage (not very much but there was a small gain) i also run the royal purpal ice (for the rad) according to the gauge it runs alot cooler
for my daily driver i run reg oil generaly the ford stuff with a ford oil filter non of that crappy fram shit
post #5 of 17 (permalink) Old 06-02-2007, 12:00 PM
I just use Castrol GTX High Mileage 5W30 in mine. I change the oil every 3 months, I could prolly go longer like 6 months since I only put about 450 Kms/Month on my truck. I change the filter to with a Motocraft one.
post #6 of 17 (permalink) Old 02-03-2008, 05:12 PM
full syn from sept-apr...high mileage from apr-sept
nnik is offline
post #7 of 17 (permalink) Old 02-05-2008, 08:43 PM
i just use what it says. I mean syn. oil is good, but its a long lasting, better protecting oil...BUT that being said, if you change your oil every 3 months or 5000KM's, do you need long lasting?
I put Synthenics into my BMW since i run it hard and in higher RPMs (not that i know it helps for sure, but it makes me feel better) but as for a DD, and you infact change it often, ide stick with the cheaper non-synthetic
E36er is offline
post #8 of 17 (permalink) Old 02-05-2008, 08:50 PM
Renault's Avatar
i herd that its not good to use fully synthetic oil on bran new engines because its two thin and they cylinders need to make there grooves first or something like that. and if you use it on really high mileage engines it may get rid of the carbon build up thats keepin it from leakin oil or something
Renault is offline
post #9 of 17 (permalink) Old 02-05-2008, 10:44 PM
I use syn. from sept to apr. b/c of the amount of time I start the truck -25+, syn. oil will not be like glue in your oil pan, I also run syn in the tranfer-case and diffs. sure makes a difference when it's cold out
nnik is offline
post #10 of 17 (permalink) Old 02-05-2008, 11:28 PM
^^ i guess i never thought of it in that sense, ive lived in a area where -5 comes like once a year and -1 like 5 times. Even where i live now max is about -10.
E36er is offline
Oil changes, who does them and who gets them done? fordtough.ca Truck/SUV Talk 97 11-22-2013 03:47 PM
What Oil? fordtough.ca Gas Engines 28 03-14-2010 10:01 PM
What engine oil do you use and When? fordtough.ca Truck/SUV Talk 10 08-15-2008 09:18 PM
What oil do you use? Smokefan Gas Engines 23 02-18-2008 08:53 PM
Engine Oil JTSF150 Gas Engines 2 09-24-2007 12:54 AM
