truck running rough - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 06-12-2009, 12:26 AM Thread Starter
fullyford's Avatar
truck running rough
well i have been chasing this problem for a couple weeks now. and the only codes left are
p01451, p0171 and p0174..the truck is still running rough at idle, stumbles on acceleration and has no power to keep highway speed...so everything that i have done has made things better but still not 100%
the p0171&4 are lean codes for bank one and two, the p1451 is evap system..this is what i have done so far...
new plugs
injectors
clean IAC
clean AIT
clean MAF
clean egr
two new O2 sensors
mil eliminators
cut out cats
pull the manifold vacuum harness off to make sure they weren't plugged
tried a new gas cap
the lean codes will also cause a misfire in 3,4 and 8 cyclinder on hard acceleration.
my next step is to try a new DPFE sensor and a evap charcoal canister..maybe change fuel filter..
anyone else had this problem before..if so please chime in and let me know what fixed your problem..also my truck is a 98 4.6l 4x4 with 270km on it...thanks in advance....
fully
http://www.f150online.com/forums/members/dirtyd88-albums-signatures-picture7437-fullyford-sig1.jpg
fullyford is offline
post #2 of 7 (permalink) Old 06-12-2009, 05:27 PM Thread Starter
fullyford's Avatar
well today i got rid of the lean codes for now, with a dpfe sonsor, also replaced the evap canister and no change
post #3 of 7 (permalink) Old 06-12-2009, 11:47 PM
Stainless's Avatar
Did you cut out the cats before the mil came on?
Stainless is offline
post #4 of 7 (permalink) Old 06-18-2009, 11:12 AM Thread Starter
fullyford's Avatar
not sure what you mean by mil. but i did things in step....all doesn't matter now, cause i had 0 compression in 3 cylinders, so i have bought an 02 4.6l out of a mustang gt that i am going to swap in
post #5 of 7 (permalink) Old 06-18-2009, 10:43 PM
Stainless's Avatar
You have mil eliminators and you dont know what mil means?
post #6 of 7 (permalink) Old 06-19-2009, 01:01 AM Thread Starter
fullyford's Avatar
you should word your question alittle better then. mils came on...how about mils put in and yes i put them in before i cut the cats out
post #7 of 7 (permalink) Old 06-19-2009, 01:22 AM Thread Starter
fullyford's Avatar
now i will have a true PI motor, ford never made a truck manifold for the PI heads but i good friend of mine has had his old one reworked and built up to match the heads. so i will have a true PI motor
2006 5.4 80,000k - Rough idle and losing power at full throttle on 3-2, 2-1 downshift tohi2care Gas Engines 7 11-01-2009 10:18 PM
2.5 rough country lift scarv F-150 Pre-1997 Forum 5 06-03-2009 10:59 PM
Rough ride stormy663 Ranger Forum 12 04-19-2009 12:18 PM
2005 5.4 rough idle and ping fourtirefire Gas Engines 2 01-27-2009 08:27 PM
