F250 5.4L V8 - Spark Plug question - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 10-09-2009, 05:34 PM Thread Starter
Hey Everyone
What would you suggest are the BEST spark plugs for a F250 with a 5.4V8 in it?
it only has 207000km on it as it hasn't been used much for the last 2 years, but now that I've taken it over I suspect to be putting 75,000 to 95,000 per year on it. maybe 10,000 of that pulling a trailer.
It wasn't taken care of very well, so I am doing a seafoam treatment on it, then going to get new plugs, and put the Lucas Oil treatment in it (http://www.lucasoil.ca/products/index.asp)
My Company has moved to buying GM so I need to make sure this F250 lasts me as long as I can get out of it.
My former 150 ran like a beauty with the iridium plugs in it,
Stephen_d is offline
post #2 of 7 (permalink) Old 10-09-2009, 06:59 PM
I think 05 was the change over to the 3V design? If so plugs might be limited to Motorcraft, Brisk and champion...Not sure.
post #3 of 7 (permalink) Old 10-12-2009, 02:12 AM
bor5.4x4's Avatar
My 04 had a 3v 5.4, anyways... I thought we could only run motorcraft in them?
bor5.4x4 is offline
post #4 of 7 (permalink) Old 10-12-2009, 02:27 AM
He has a f250. I think 05 was the first year for the 3V in those.
post #5 of 7 (permalink) Old 10-13-2009, 05:04 AM
zip
zip's Avatar
Motorcraft plugs would be the wise choice. They seem to run best with the OE plugs.
Chris
75 F150, 79 Bronco
zip is offline
post #6 of 7 (permalink) Old 10-13-2009, 11:35 PM
05 should be a 3v 5.4l,i would suggest using motorcraft plugs in it,and make sure to use some anti seize on the threads and the lower portion of plug.
post #7 of 7 (permalink) Old 10-14-2009, 12:49 AM
zip
zip's Avatar
One more thing to remember.
Make certain they are torqued correctly.
Chris
75 F150, 79 Bronco
zip is offline
Spark Plug Types BigDawg99 F-150 2004 to 2008 Forum 18 07-11-2009 04:00 PM
Spark plug clarification... Armen F-150 2004 to 2008 Forum 18 03-10-2009 02:46 PM
Spark plug price ????? star69 F-150 2004 to 2008 Forum 6 11-22-2008 01:46 PM
spark plug help Grizzly F-150 2004 to 2008 Forum 7 10-05-2008 11:16 AM
engine spit out spark plug. MRGADGET Gas Engines 17 02-22-2008 01:01 PM
