NEED HELP: 2002 f150 won't start unless steering colum is down - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 12-05-2009, 11:46 AM Thread Starter
Thumbs down 2002 f150 won't start unless steering colum is down
my brother 2002 F150 will not start unless his steering column is down does any one know what is causing this? any help would be great>
HOTDOG is offline
post #2 of 3 (permalink) Old 12-05-2009, 06:09 PM
Howdy. I always fill up my tank in Beaverlodge on the way back from GP.
Sounds like you've either got a loose connector on the wiring harness, or a wire about to break. I'd start by removing the plastic cover around the streering column and tracing the wiring harness back from the ignition switch. Have a good look and see if there's any broken or chafed insulation. Pull the connectors and check the contacts to make sure they're not oxidized, and then re-plug them a few times. See what effect that has.
post #3 of 3 (permalink) Old 12-05-2009, 06:10 PM
multifunction switch
Remote start won't start MrSen F-150 2004 to 2008 Forum 8 12-04-2009 07:58 PM
2002 f150 shift on the fly Haley-Special F-150 1997 to 2003 /04 Heritage Forum 11 10-02-2009 02:42 PM
2002 F250 suspension Renault Super Duty Forum 14 09-19-2009 01:42 PM
