4.6L 3v truck/mustang comparison - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 02-18-2010, 12:36 AM Thread Starter
Is the only difference between these motors the block material (aluminum vs steel), or is there more to it than that?
JoeFord is offline
post #2 of 8 (permalink) Old 02-18-2010, 12:58 AM
the cams are different. The powerbands are different.
post #3 of 8 (permalink) Old 02-18-2010, 01:42 AM Thread Starter
anything else?
JoeFord is offline
post #4 of 8 (permalink) Old 02-18-2010, 10:57 AM
intake, cams, tune,
post #5 of 8 (permalink) Old 02-18-2010, 07:03 PM
Intake, Cams, Tune and entirely different powerband. Not to mention that the truck engine is rated a 292hp/320trq and the Mustang is rated at 300hp/320trq.
post #6 of 8 (permalink) Old 02-19-2010, 02:44 AM Thread Starter
So what does all that mean exactly?
JoeFord is offline
post #7 of 8 (permalink) Old 02-19-2010, 09:05 AM
it means with the truck motor its got a bit more lower end grunt but the peak hp isnt as good (not by much) its designed for towing where the stang motor is all about the hp
it wont effect the install of the motor just effects the performance of it.... you can change all that with block work and head work theres a ton of info on the 4.6/5.4 for hp upgrades on the net there a good performer when done right
post #8 of 8 (permalink) Old 02-19-2010, 06:09 PM Thread Starter
Yeah, Ive been reading about it, but lots of the info is for the 2v version, and apparently the parts compatibility is bad on these motors.
Is the aluminum block just to save weight?
JoeFord is offline
1977 Mustang 2 Rangerdude1987 Other Ford Models 6 06-13-2009 08:03 PM
Ranger/Mustang CanadianRanger Truck/SUV Talk 10 04-02-2008 08:26 PM
