NEED HELP: truck starts but turns off - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 05-22-2010, 03:03 AM Thread Starter
Mechanic
hawker250's Avatar
i've got a 1990 f250 5.8L. you can start it, but when the key turns to the run position it shuts off.
Changed the ignition switch and lock cylinder, did not fix problem.
Changed steering column, but i think i got a bad one from the wrecker.
hawker250 is offline
post #2 of 11 (permalink) Old 05-22-2010, 09:29 AM
is it stalling or do you mean you lose all power?
post #3 of 11 (permalink) Old 05-22-2010, 12:57 PM Thread Starter
Mechanic
hawker250's Avatar
i lose all power
post #4 of 11 (permalink) Old 05-22-2010, 02:28 PM
My '80 did a similar thing. Replaced the ignition switch at the bottom of steering column. Good now. It's a bit of a pita job. Have to unbolt column from underneath dash and remove bracket to get at switch. 20 bucks for part. Here is what I'm talking about: http://cgi.ebay.com/ebaymotors/Ignit...item3ef73cf834. Good luck.
post #5 of 11 (permalink) Old 05-22-2010, 03:05 PM Thread Starter
Mechanic
hawker250's Avatar
yeah the ignition switch was the first the thing i changed and it doesn't seem to be the problem
post #6 of 11 (permalink) Old 05-22-2010, 09:53 PM
Does everything power up before starting? Key in run position?
post #7 of 11 (permalink) Old 05-23-2010, 02:48 PM Thread Starter
Mechanic
hawker250's Avatar
when i put the key in run position there is no power. when i turn the key to the start position, about half way the truck powers up and then the truck will start. If i hold the key the truck will run, but soon as i let go the truck loses power.
post #8 of 11 (permalink) Old 05-23-2010, 05:11 PM
do you have a Hayne's manual for the truck? You've got a wiring issue. Welcome to owning a pre97 lol
post #9 of 11 (permalink) Old 05-23-2010, 11:39 PM Thread Starter
Mechanic
hawker250's Avatar
well problem solved. Yes it was a wiring problem. a little bit of hillbilly wiring when the owners before me installed a alarm system. well a connector came lose from a relay that i didn't notice and when the steering column was lowered more things came unconnected making it harder to solve. i guess the simplest problem can be the most troubling.
Thanks for all the help i appreciate it!
brad
post #10 of 11 (permalink) Old 05-24-2010, 12:00 AM
Hey now, be nice. It could be worse, he could have a post 96.
Fun day Mudding Turns into this.. Coruptyed Photo and Video Gallery - Members Rides 51 01-22-2011 11:27 AM
