Temperature guage - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 08-14-2010, 01:54 PM Thread Starter
Temperature guage
The temp gauge is not working on my 1981 Ford Motor home. This unit has a Ford 460 CID engine. The sensor is located near the distributor.
My question is how can I test this sensor? And can I test the wiring back to the gauge by using a Ohm meter with the ignition turned on?
Thanks in advance....
The Older I get the better I was!!
Knightruler is offline
post #2 of 4 (permalink) Old 08-16-2010, 02:36 PM
just unplug sensor and the guage should go full cold then ground sensor wire and should go full hot.
post #3 of 4 (permalink) Old 08-16-2010, 03:48 PM Thread Starter
I just tried that. I got no response from the guage at all. I tried both with it running and not, with ignition on!!
What did I prove?
post #4 of 4 (permalink) Old 08-17-2010, 02:33 PM
you have a gauge concern in cluster.or the wiring.
flickering digital odometer /temp guage xdallairex F-150 2004 to 2008 Forum 3 05-15-2010 08:02 PM
NEED HELP: Fuel guage fluctuates sometimes.... Arctic F-150 F-150 2004 to 2008 Forum 11 07-08-2009 11:20 PM
Temperature control Bates88 F-150 2004 to 2008 Forum 16 03-17-2009 01:58 AM
What Transmission Temperature......... fordtough.ca Driveline and Transmission 1 06-28-2008 11:02 PM
