Storage advise - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 09-05-2010, 04:47 PM Thread Starter
Storage advise
I recently purchased an older (1981) Scamper motor home with a ford 460 engine and Auto trans. I then replaced all the gaskets and seals(almost). The valve cover gaskets the oil pan and rear seal.
I am assuming I had to replace all this because this vehicle was stored for long periods(several years). And they dried up.
I don't want to have replace these things again so I plan to start it up every once in awhile. It's going into storage for the winter in a couple of weeks.
My question is what time frame should I start it up and let her run. I was thinking about once a month. What do you think?
The Older I get the better I was!!
Knightruler is offline
post #2 of 3 (permalink) Old 09-05-2010, 07:44 PM
when I store my 96 I fire it up once a month and let it run till she gets in the normal operating temp
post #3 of 3 (permalink) Old 09-05-2010, 09:49 PM
Once a month I fire up the '87 Harley ,and for every 20 liters of fuel I add 2 Cups of methyl hydrate to keep the gas from gumming up the carb,assuming your '81 460 isn't fuel injected.Ogre
Ogre is offline
winter storage fordfan22 Other Ford Models 6 09-05-2009 04:29 AM
overhead storage macs07 F-150 2004 to 2008 Forum 4 11-24-2008 11:21 AM
