NEED HELP: Engine block heater - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 12 (permalink) Old 01-01-2011, 09:48 AM Thread Starter
Engine block heater
My brother has a 2001 F-150 XTR 4x4 and it has the Engine block heater on it and he is wondering if it's works or not!!!!
post #2 of 12 (permalink) Old 01-01-2011, 10:25 AM
1 way to find out is to plug it in wait a few hours then go put your hand on a rad hose or down on the block.
post #3 of 12 (permalink) Old 01-01-2011, 11:46 AM
i can actually hear mine when the engine is cold and it gets plugged in.
post #4 of 12 (permalink) Old 01-01-2011, 02:25 PM
swackly's Avatar
Plug it in for a few minutes, then unplug it you should see a power ark if it is working
swackly is offline
post #5 of 12 (permalink) Old 01-01-2011, 03:01 PM
FX4Ranger's Avatar
leave it plugged in over night and when you get in it in the morning your ECT should be near the bottom of the range
07 FX4 Level II Ranger
89 Bronco II
Rust in Pieces
FX4Ranger is offline
post #6 of 12 (permalink) Old 01-01-2011, 03:13 PM
actually it should arc when you plug it in but that don't mean the heater itself is working, just means it has hydro. I know this for fact as 2 years ago I pulled in a transport at work in the a.m and in the late afternoon went to start it and it was cold block heater didn't work but it arced at the plug.
post #7 of 12 (permalink) Old 01-01-2011, 03:23 PM
Unplug the block heater. Measure the resistance across the two flat prongs of the plug (hot and neutral) with an ohm-meter. You should get a very low resistance reading, maybe something like 2 -- 100 ohms, something in that neighbourhood.
A very high resistance (in the megaohms) or "open", would indicate the heating element is burned out, or there is a problem with the cord.
post #8 of 12 (permalink) Old 01-01-2011, 04:08 PM Thread Starter
Maybe a Dumb question: BUT what does ECT stand for!!!!!
post #9 of 12 (permalink) Old 01-01-2011, 04:21 PM
engine coolant temperature Gordon.
post #10 of 12 (permalink) Old 01-01-2011, 04:31 PM Thread Starter
THANKS Glen!!!!
Inline Tank/Circulation block heaters rvx290 F-150 2004 to 2008 Forum 3 11-21-2010 11:29 PM
Another kid on the block SavageVertigo New Members Introductions 12 08-31-2010 07:33 AM
big block? 94f150 F-150 Pre-1997 Forum 6 05-26-2010 11:16 PM
Inline block heater Justin1635 Raptor, Harley-Davidson, Limited, King Ranch, 60th Anniversary, Platinum 5 01-05-2010 12:46 AM
BLOCK HEATER MississaugaRanger Ranger Forum 30 03-06-2009 11:28 PM
