4.0 won't start - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 21 (permalink) Old 01-19-2011, 10:13 PM Thread Starter
4.0 won't start
It ran fine yesterday on the way to work and back and one more short trip after that. Then it would not start last night. It turns over but will not fire. It is getting spark and I cleaned the CPS but am buying a new one tomorrow, also changed the fuel filter. I am also going to check and make sure it's getting fuel tomorrow by pulling the fuel line off the filter and cranking the engine. Any suggestions? Sure hope it's not the fuel pump.
post #2 of 21 (permalink) Old 01-19-2011, 10:23 PM
Inertia switch?
post #3 of 21 (permalink) Old 01-19-2011, 10:33 PM Thread Starter
It's good, and all the fuses are good.
post #4 of 21 (permalink) Old 01-19-2011, 10:35 PM
fuel pump relay?
post #5 of 21 (permalink) Old 01-19-2011, 10:37 PM
Frozen fuel line?
post #6 of 21 (permalink) Old 01-19-2011, 10:40 PM
When you turn the key on do you hear the fuel pump ? Being the year of your truck I'm thinking it's the fuel pump. if not there should be a push button switch to reset it, try again if nothing than your fuel pump maybe toast.
post #7 of 21 (permalink) Old 01-19-2011, 11:03 PM Thread Starter
Tried the fuel pump relay from my sisters Explorer (96) and no go.
It's been parked in the garage for 24hrs now and fuel came out of the filter, maybe a line after the filter frozen? I'll put a heater under it in the morning.
No I don't hear the pump when I turn the key on. Are you talking about the fuel pump shut off switch? I'll check it again tomorrow.
Probably the pump but I'm gonna try the new CPS first. REALLY not looking forward to dropping the tank lol So if fuel comes out of the line when I crank the engine with the line dissconected from the filter the pump is good right?
post #8 of 21 (permalink) Old 01-19-2011, 11:30 PM
If you want to check the fuel system, probably an easier way is to connect a fuel pressure gauge to the schrader valve on the fuel rail under the hood. This would tell you:
1) that the pump is producing sufficient pressure to operate with the injectors
2) that you're getting fuel through to at least the fuel rail.
Another thing to check is the gas cap. It should be relieving the vacuum in the tank. In other words, you shouldn't get a "pop" when you take it off.
In the meantime, I'd pour some gas line antifreeze into the tank. Do you keep the tank over half-full in the winter?
(What's a 'CPS'?)
post #9 of 21 (permalink) Old 01-20-2011, 01:22 AM
I'm leaning towards fuel pump myself.
post #10 of 21 (permalink) Old 01-20-2011, 03:29 AM
Its missing 2 cylinders, thats why! It needs a V8 to run properly anyways LR
No start mystery garymac221 F-150 2004 to 2008 Forum 12 01-06-2012 02:30 AM
Remote start won't start MrSen F-150 2004 to 2008 Forum 8 12-04-2009 07:58 PM
NEED HELP: Wouldnt Start Scotts Black FX4 F-150 2004 to 2008 Forum 2 07-21-2009 12:11 AM
Where should I start wolfman1 SVT Lightning 28 04-15-2009 01:15 PM
HELP! truck won't start! lightning25 Gas Engines 14 01-18-2009 03:03 PM
