FordTough.ca - Home of Canadian Ford Truck Enthusiasts
FordTough.ca - Home of Canadian Ford Truck Enthusiasts (https://www.fordtough.ca/forums/)
-   F-150 2009 to 2014 Forum (https://www.fordtough.ca/forums/176-f-150-2009-2014-forum/)
-   -   break in period (https://www.fordtough.ca/forums/176-f-150-2009-2014-forum/15049-break-period.html)
macs07 01-03-2014 09:56 AM
break in period
I have a 2013 FX4 with 2600 miles. it is a 5 L with 3.55 gears and adverage fuel at about 16.9 miles per gal. 12 liters per 100 km
is there a break in period for the engine? does the cold weather effect fuel milage?? Thanks for any info.
SVT4MT 01-03-2014 10:49 AM
I think break in periods are a thing of the past, if there's nothing in the Owner Manuals, don't worry about it.
I'm at 7000 km on mine with the 3.73's and I'm getting pretty much the same mileage if that's any help.
Mileage depends a lot on how you drive, and how much city vs highway you do, can't say whether colder, denser air will make a huge difference in the winter or not.
I have heard some speculation that the 5.0's improve somewhat over the first six months or so of driving, and my numbers did get a little better from new, but that's purely speculation and not a documented fact.
herbz 01-03-2014 11:15 AM
I agree, break-in period is a thing of the past. Cold weather will affect your mileage a bit. Most people say 1 or 2 mpg, gas stations change their blends a bit for winter.
My dad has an 11' FX4 5.0 3.73's with 90k on it, driving is 90% highway and it has stayed at 14L/100km no matter how you drive it from new.
TRNRBILT 01-03-2014 05:23 PM
Different gas in the winter which usually ends up being worse for mileage. I average about 18mpg in the summer months and 16mpg in the winter months.
Viper238 01-03-2014 08:01 PM
My 5.0 got better mileage around the 20k.
I average 12-13l/ 100kms in summer.
14-15l/100kms in winter.
The colder denser air in the winter will cause a denser charge which will cause the computers to compensate with additional fuel to equalize the A/F mixture. Hence worsens fuel mileage.
winter fuel.. Basically they take some of the additives out. Cost them less to produce the gas yet price doesn't usually go down.. :(
http://<br /> http://auto.howstuffwo...fuel.htm<br />
Unfortunately for drivers, gas prices often go up during the summer, starting around Memorial Day [Source: EPA]. There are many reasons behind the increase in summer fuel prices, and some are fairly logical. More people traveling, especially on family vacations and road trips, increases demand. Also, in the spring months, energy companies conduct maintenance on their refineries, shutting them down and limiting capacity until late May. Because of these disruptions, oil supplies can become stretched. In addition, natural disasters, like hurricanes, can increase prices by disrupting transport routes and damaging refineries and other infrastructure.
But did you know that the gasoline sold during the summer is actually different -- and more expensive to produce -- than that sold in the winter? In this article, we'll take a look at why summer fuel prices are higher, focusing on the annual shift from winter-grade fuel to summer-grade fuel.
Twice every year in the United States, the fuel supply changes. It's known as the seasonal gasoline transition. This change is the biggest reason for the price hike in summer gasoline. Depending on the time of year, gas stations switch between providing summer-grade fuel and winter-grade fuel. The switch started in 1995 as part of the Reformulated Gasoline Program (RFG), which was established through the 1990 Clean Air Act Amendments. The Environmental Protection Agency (EPA) started the RFG program in order to reduce pollution and smog during the summer ozone season, which occurs from June 1 to Sept. 15 [Source: EPA].
In order to reduce pollution, summer-blend fuels use different oxygenates, or fuel additives. These blends, the EPA claims, burn cleaner and also help compensate for a limited oil supply. The EPA says this practice of using seasonal blends also encourages the development of alternative fuels [Source: EPA]. (Remember that gasoline isn't just made up of processed crude oil -- it's a blend of refined crude oil and different compounds and additives.)
So what's the difference between summer-grade fuel and winter-grade fuel? Summer-grade fuel is more expensive for two reasons -- because of the ingredients it contains and because refineries have to briefly shut down before they begin processing it. Summer-grade fuel also burns cleaner than winter-grade fuel. This just means that it produces less smog and releases less toxic air pollutants, which we'll talk about more [source: EPA]. The actual difference in cost of production varies. One estimate claims an increase of only 1 cent to 2 cents per gallon [Source: Slate], while another states 3 cents to 15 cents per gallon [Source: Reason]. No matter the difference in production costs, the increase at the pump is even greater, owing to the summer driving season, dips in supply, maintenance costs and companies' converting to production of summer blends.
During the summer, pollution is a frequent concern due to increased levels of smog and ozone, which can harm the lungs. Summer heat boosts the formation of ozone, while the appearance of an inversion layer -- an immobile layer of air -- can trap pollutants in the lower atmosphere [source: EPA].
Summer-grade fuel has a different Reid Vapor Pressure (RVP) than winter-grade fuel, which contributes to its being (marginally) more eco-friendly. RVP is the vapor pressure of gasoline measured at 100 degrees Fahrenheit. Fuels with higher RVP evaporate more easily than those with lower RVP. A particular fuel blend's RVP is based on the combined RVP of the ingredients that make up the blend. Regulators worry about this evaporation because it contributes to ozone formation.
Gasoline must have an RVP below 14.7 PSI (pounds per square inch), which is normal atmospheric pressure; if a fuel's RVP were greater than 14.7 PSI, excess pressure would build up in the gas tank, and the fuel could boil and evaporate. Depending on the part of the country, the EPA's standards mandate an RVP below 9.0 PSI or 7.8 PSI for summer-grade fuel. Some local regulations call for stricter standards. Because of these varying RVP standards, up to 20 different types of boutique fuel blends are sold throughout the U.S. during the summer [Source: Slate].
Because RVP standards are higher during the winter, winter-grade fuel uses more butane, with its high RVP of 52 PSI, as an additive. Butane is inexpensive and plentiful, contributing to lower prices. Summer-grade fuel might still use butane, but in lower quantities -- around 2 percent of a blend [Source: The Oil Drum].
We know that gas prices go up during the summer, generally around Memorial Day, but when do companies start producing these different summer fuels? The EPA defines April to June as the "transition season" for fuel production [Source: EPA]. Refineries switch over to summer-blend production in March and April [Source: EPA]. Gas stations have by June 1 to switch to selling summer-grade gas, while terminals and other facilities "upstream" from pumping stations have to switch by May 1 [Source: EPA]. Following the summer driving season, companies switch back to winter blends beginning in September, with the first winter increase in RVP allowance occurring on Sep. 15.
In a 2001 report, the EPA claimed that "roughly 75 million Americans breathe cleaner air today due to [the seasonal fuel] program" [Source: EPA]. Still, the increased price, combined with the use of controversial additives like ethanol (which is less energy efficient than gasoline and produces more smog) and methyl tertiary butyl ether (MTBE), means that the program may still have its detractors.
STORING FUEL OUT OF SEASON
Because of the way winter and summer fuels react under different atmospheric pressures, particularly in terms of evaporation, it's important to use summer and winter fuels during their respective seasons. Fuel that's stored out of season can evaporate. It can also hurt engine performance.
Sent from my iPhone using Tapatalk
Canadian Bacon 01-06-2014 09:23 AM
Break in period is 1000KM on Ford vehicles. You shouldn't use your cruise for that period after that your good to go.
Viper238 01-06-2014 10:57 AM
My 2009 manual said break in was first 1200kms. I couldn't tow anything till after that.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
****Powered by vBulletin ****Copyright © 2000-2008 Jelsoft Enterprises Limited.****FORDTOUGH.CA AND FORD-TRUCKS.CA ARE NON-PROFIT ORGANIZATION/CLUB DEDICATED TO CANADIAN FORD TRUCKS ENTHUSIASTS. FORDTOUGH.CA AND FORD-TRUCKS.CA ARE NOT AFFILIATED WITH FORD MOTOR COMPANY OR ANY OF ITS SUBSIDIARIES, AND IS NOT RESPONSIBLE FOR THE CONTENT ADDED BY ITS MEMBERS. IN NO EVENT SHALL WWW.FORDTOUGH.CA AND WWW.FORD-TRUCKS.CA AND/OR ITS RESPECTIVE CONTRIBUTORS BE LIABLE FOR ANY SPACIAL, INDIRECT OR CONSEQUENTIAL DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF INFORMATION AVAILABLE FROM THE SERVICES ON THIS SITE.
