1 - 4 of 4 Posts
Hi there. I have a 2000 Ford F250 with the 7.3L power stroke. The 4x4 on the truck does not work at all, no 4x4 light, no clicking sounds, nothing. All the fuses and relays are good, 4x4 switch is good, everything is working good on the truck other than the 4x4. Any suggestions on what it might be would be greatly appreciated. Thanks
Welcome aboard. Check the electric shift unit on the transfer case. If I recall correctly, it can be unbolted from the transfer case.
Do you have a GEM module? If so, have you verified it's working properly?
1 - 4 of 4 Posts
