Just in case you need a laugh: Remember it takes a college degree to fly
a
plane but only a high school diploma to fix one.
Reassurance for those of us who fly routinely in our jobs.
After every flight, Qantas pilots fill out a form, called a "gripe
sheet,"
which tells mechanics about problems with the aircraft.
The mechanics correct the problems, document their repairs on the form
and,
then pilots review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humor.
Here are some actual maintenance complaints submitted by Qantas'
pilots (marked with a P) and the solutions recorded (marked with an
S) by maintenance engineers.
By the way, Qantas is the only major airline that has never, ever, had
an
accident.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very roug h.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute
descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: Friction locks cause throttle levers to stick.
S: That's what friction locks are for.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny. (I love this one!)
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
And the best one for last..................
P: Noise coming from under instru ment panel. Sounds like a midget
pounding
on something with a hammer.
S: Took hammer away from midget
a
sheet,"
and,
an
accident.
descent.
S: Cat installed.
pounding
