Get the look you want on your Ford F150 without compromising the comfort of your ride with a set of Belltech Lowering Spindles! These spindles feature solid construction and are made to last. They also exceed OEM quality standards without affecting wheel alignment in your truck.
Reinforced, heavy-grade steel provides the strength and rigidity needed to withstand heavy loads and accommodate large tires. A durable powder-coat finish effectively protects steel surfaces from corrosion. After installation, the reduced ride height lowers your truck's center of gravity, which, in turn, reduces body roll and any tendencies to lean over.
This summer, we are pleased to announce an amazing summer offer from Belltech! Catch the best prices possible – you can buy Belltech Drop Spindles with a 15% discount! This offer is valid till August 31, 2021, only. Prices are already reduced.
