on the 98 ford f-150 , 5.4l tirton. from what i can see it looks like i need to pull the fuel rails to get at the coil over packs and to remove the plugs? if i loosen the 2 little bolts that atatch the fuel rail to the manifold, i should be able to pull the fuel rail up and the injectors should just come with it right?
ray:
