DTC List
I hope this helps some of you out
DTC Index
PCM - Powertrain Control Module
P0010 Intake Camshaft Position Actuator Circuit/Open (Bank 1)
P0011 Intake Camshaft Position Timing - Over-Advanced (Bank 1)
P0012 Intake Camshaft Position Timing - Over-Retarded (Bank 1)
P0016 Crankshaft Position - Camshaft Position Correlation - Bank 1 Sensor A
P0018 Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor A
P0020 Intake Camshaft Position Actuator Circuit/Open (Bank 2)
P0021 Intake Camshaft Position Timing - Over-Advanced (Bank 2)
P0022 Intake Camshaft Position Timing - Over-Retarded (Bank 2)
P0040 Oxygen Sensor Signals Swapped Bank 1 Sensor 1/Bank 2 Sensor 1
P0041 Oxygen Sensor Signals Swapped Bank 1 Sensor 2/Bank 2 Sensor 2
P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
P0068 Manifold Absolute Pressure (MAP)/Mass Air Flow (MAF) - Throttle Position Correlation
P0102 Mass or Volume Air Flow A Circuit Low
P0103 Mass or Volume Air Flow A Circuit High
P0104 Mass or Volume Air Flow A Circuit Intermittent/Erratic
P0106 Manifold Absolute Pressure (MAP/BARO) Sensor Range/Performance
P0107 Manifold Absolute Pressure (MAP)/Barometric Pressure (BARO) Sensor Low
P0108 Manifold Absolute Pressure (MAP)/Barometric Pressure (BARO) Sensor High
P0109 Manifold Absolute Pressure (MAP)/Barometric Pressure (BARO) Sensor Intermittent
P0112 Intake Air Temperature (IAT) Sensor 1 Circuit Low
P0113 Intake Air Temperature (IAT) Sensor 1 Circuit High
P0114 Intake Air Temperature (IAT) Sensor 1 Intermittent/Erratic
P0116 Engine Coolant Temperature (ECT) Sensor 1 Circuit Range/Performance
P0117 Engine Coolant Temperature (ECT) Sensor 1 Circuit Low
P0118 Engine Coolant Temperature (ECT) Sensor 1 Circuit High
P0119 Engine Coolant Temperature (ECT) Sensor 1 Circuit Intermittent/Erratic
P0121 Throttle/Pedal Position Sensor A Circuit Range/Performance
P0122 Throttle/Pedal Position Sensor A Circuit Low
P0123 Throttle/Pedal Position Sensor A Circuit High
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
P0127 Intake Air Temperature (IAT) Too High
P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
P0132 O2 Circuit High Voltage (Bank 1, Sensor 1)
P0133 O2 Circuit Slow Response (Bank 1, Sensor 1)
P0135 O2 Heater Circuit (Bank 1, Sensor 1)
P0138 O2 Circuit High Voltage (Bank 1, Sensor 2)
P0141 O2 Heater Circuit (Bank 1, Sensor 2)
P0144 O2 Circuit High Voltage (Bank 1, Sensor 3)
P0147 O2 Heater Circuit (Bank 1, Sensor 3)
P0148 Fuel Delivery Error
P0152 O2 Circuit High Voltage (Bank 2, Sensor 1)
P0153 O2 Circuit Slow Response (Bank 2, Sensor 1)
P0155 O2 Heater Circuit (Bank 2, Sensor 1)
P0158 O2 Circuit High Voltage (Bank 2, Sensor 2)
P0161 O2 Heater Circuit (Bank 2, Sensor 2)
P0171 System Too Lean (Bank 1)
P0172 System Too Rich (Bank 1)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
P0180 Fuel Temperature Sensor A Circuit
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low
P0183 Fuel Temperature Sensor A Circuit High
P0190 Fuel Rail Pressure Sensor A Circuit
P0191 Fuel Rail Pressure Sensor A Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor A Circuit Low
P0193 Fuel Rail Pressure Sensor A Circuit High
P0196 Engine Oil Temperature (EOT) Sensor Circuit Range/Performance
P0197 Engine Oil Temperature (EOT) Sensor Circuit Low
P0198 Engine Oil Temperature (EOT) Sensor Circuit High
P020x Injector Circuit/Open - Cylinder X
P0210 Injector Circuit/Open - Cylinder 10
P0217 Engine Coolant Over-Temperature Condition
P0218 Transmission Fluid Temperature Over-Temperature Condition
P0219 Engine Over Speed Condition
P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance
P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low
P0223 Throttle/Pedal Position Sensor/Switch B Circuit High
P0230 Fuel Pump Primary Circuit
DTC Index
