Get Enhanced Stopping Performance with Baer I Claw Brake Pads for F-150
209 views 3 replies 2 participants last post by  CARiD
#1 ·
Even in its base form, your latest-generation F-150 is an impressive truck that delivers exceptional capability when used as a workhorse and provides thrills when you’re driving deeper into the desert or challenging off-road terrain. Whatever the task, it requires a reliable set of brake pads that will provide optimum braking power with minimum noise and dust. Engineered to handle the demands of both daily driving and high-performance situations, our all-new Claw Ceramic Front Brake Pads by Baer offer improved stopping power in all weather conditions.
They feature a ceramic compound formulated to provide long-lasting, consistent performance and are guaranteed to last a lifetime while offering low rotor wear. Each pad set includes stainless steel abutments and anti-rattle hardware.
Baer® - Claw Ceramic Front Brake Pads
  • Series Claw;
  • Backing Plate Color Black;
  • Emission Code 6;
  • Grade Type Premium;
  • Slotted Yes;
  • Wear Indicator Attached No;
  • Friction Material Ceramic;
  • Hardware Option Included;
  • Driving Style Daily Driver;
  • Clips Option With Clips;
  • Brake Lube Not Included;
  • Dependable, Consistent Performance with Minimal Noise and Low Dust;
  • Premium High Friction Ceramic Compound;
  • Long pad life with low rotor wear;
  • Delivers a Great Balance Between Maximum Performance and Road-Going Civility;
  • Stainless Steel Abutment and Anti-Rattle Hardware Included with Most Pads;
It's a simple upgrade that creates a big impact. Baer Claw Brake Pads are engineered for a precise fit, so they are easy to install, typically following the same process as OEM brake pad replacements.
#2 ·
Enhanced braking performance is just a few clicks away!
Upgrade your 2024 Ford F-150 with Baer and ensure it can handle the demands of both daily driving and high-performance situations.
Explore more brake system components and learn more about the manufacturer here: https://www.carid.com/baer/
