Every printer now and then shows this type of error so there is nothing to worry about. It might be frustrating at once but when you will get to know how to fix brother printer offline issues, it will look like a child’s play to you.
Here are a few things to check to troubleshoot the issue permanently-
• Check if your printer is getting proper power from the power source.
• Check the network connectivity
• Check your printer settings.
For that Go to your system, open printers and devices, click on the printer you are using and check its status. Sometimes, ‘Use printer in offline mode’ is checked. Uncheck it and your printer will be back online and running.
