In 2022, if your F-150 is still equipped with factory halogen headlights, then you're awfully behind the times! The new Morimoto XB LED headlights not only look perfect but they also very well-built and will last a lifetime. The company claims that these LED headlights are the best on the market that you can use to upgrade the Ford F-150 lighting. One of the main advantages of Morimoto products is their precise fitment and flawless look. And of course, the new Morimoto XB LED headlights produce a wide, well-defined beam pattern of high-intensity light that is distributed evenly on the road surface.
The upgrade to the new XB projector LED headlights cannot compare to the simple retrofitting of your stock reflector housings with new LED bulbs. Morimoto’s headlights feature triple-projector optics that meet and even exceed all SAE, DOT, and FMVSS108 regulations. They are very easy to adjust for proper beam aim. You don’t need to modify your Ford’s wiring to install these headlights. All you need to do is plug into the factory connectors. Besides, the installation will not void your factory warranty.
Click the link below to read more:
Morimoto Introduced New XB LED Projector Headlights for Ford F-150
Arguably the best looking and best-performing aftermarket LED projector headlights for the Ford F-150 on the market today. These lamps will become a huge upgrade compared to the factory equipment.
www.carid.com
To browse the full catalog of Morimoto lighting products, use the link below:
Morimoto™ | LED Fog Lights, HID Projectors, Bulbs — CARiD.com
If you’re looking for performance, quality, and reliability, you can’t beat Morimoto. Shop our large selection for products that will more than meet your needs.
www.carid.com
Give our sales team a call at 800.505.3274 (Toll-Free) or 1.609.642.4700 (International) and we'll answer all your questions.
