There is a new Ford Extended Service Plan available designed for high mileage diesel drivers. If your truck is still under 5 year/160,000 KMS you purchase a diesel engine warranty up to 300,000 kms. There are 2 types, Diesel Care and Diesel Care Total. The price is $1,480 and $2,465, plus a $100 surcharge if the vehicle is beyond 1 yr or 20,000 kms. We also offer up 17 month finance at 0%. There is an admin fee. 6.0L and 6.4L models only
DieselCARE Covered Components
ENGINE
• All internal lubricated parts
• Accelerator switch
• Camshaft position sensor
• Crankshaft position sensor
• Cylinder block
• Cylinder heads
• Electronic driver unit
• Engine control module
• Exhaust back pressure regulator
and sensor
• Exhaust pressure sensor
• Flywheel
• Fuel rail pressure sensor
• Fuel system (excluding fuel lines,
fuel tank, and frame mounted fuel
conditioning module)
• Harmonic balancer
• High pressure fuel injection
pump assembly
• High pressure oil regulator
DieselCARE Total Covered Components
• High pressure lines
• Injection pressure sensor
• Injectors
• Intake air temperature sensor
• Glow plugs
• Manifolds (intake/exhaust)
• Manifold pressure sensor
• Oil pan
• Oil pump
• Powertrain control module
• Seals and gaskets
• Thermostat
• Thermostat housing
• Timing chain cover
• Timing chain (gears or belts)
• Turbocharger/supercharger unit
(factory-installed)
• Valve covers
• Water pump
ENGINE
• Cylinder block
• Cylinder heads
and sensor
• Flywheel
• Harmonic balancer
pump assembly
• Injectors
• Glow plugs
• Oil pan
• Oil pump
• Seals and gaskets
• Thermostat
(factory-installed)
• Valve covers
• Water pump
