Increase the versatility of your 2021 Ford Bronco, improve its exterior styling and get it properly prepared for the off-road season with the brand-new, innovative ActionTrac lifted truck steps crafted by Aries. These are next-generation running board upgrades aimed to highlight the aggressive and tough nature of your SUV while providing you with the sure leg up every time you're entering or exiting the cabin.
They are currently available in a cab-length size only and could offer an 8" drop from the 4" wide top step and up to 15" from the doorsill for convenient entrance and descending. ActionTrac Running Boards are constructed from the extruded 6061-T6 aluminum covered with a carbide black powder coat finish, which makes them 100% resistant to corrosion and minor damages.
Aries - ActionTrac 69.6" Powered Running Boards
Fits: 2021 Ford Bronco 4-Door
Notes:
Includes one pair of running boards, mounting hardware and wiring harness
These boards are not a substitute for rocker bars
65" stepping surface, 69.6" overall length
  • hipping Weight: 72.000
  • Material: Aluminum
  • Finish: Carbide Black Powder Coat
  • Warranty: Limited Lifetime Warranty (Five-Year Finish, Three-Year Parts)
  • Patented step-within-a-step design for easier access, especially on large vehicles
  • 3" powered step automatically drops 8" when door opens, up to 15" below doorsill
  • 4" top step provides convenient access to the roof of the vehicle
  • Housing shields retractable step, pivot points and electronics from the elements
  • Contoured design helps protect the rocker panels from road debris and door dings
  • Simple-2-install system with no-drill brackets and no-splice wiring
  • Powder-coated 6061-T6 aluminum is durable, lightweight and non-corrosive
  • Integrated control module detects obstructions and eliminates pinch hazards
  • Single, rotary motor for fast, quiet, maintenance-free operation
  • Integrated LED lights activate on deployment for added visibility and safety
  • Rated for 650 lbs. static weight capacity
  • Assembled in USA
Get full information about the new Aries release here.
