Heres some pics of my 2004 F-350 lariat long box,
When I ordered truck i ordered it with stainless rocker panels, under coating, wooden box liner, window drip rails , hood Vailance,as well had them put in the High idle set up lol.
I told them to take of the steering stablizer off i didn't want that. Also ordered it with the life time no rust guarntee thingy hahaha. My truck body and frame is electricly charged suppose to work i can sorta see it in Theory But most importantly i ordered it with the Donohoe racing 6" lift it came with 37" pro-comp tires,6 bilestien shocks. So literally I spent 10G on top of price for Mods before i even seen the truck hahahaa.
So i drove it and got the stares looked wicked, no problems with it i was Happy. till i started seeing Dodges, and Chevs that were lifted taller. lmao
I wasn't going to let that happen,So i talked to a RCMP friend and asked about the laws on lifted trucks etc.then i started searching the net and started planning my next lift which was to go Big lol So heres some pics oftruck total lift 28" I used 8" deaver springs, Dr crossover steering, track bar, steerin pitman arm, dual shock front mounts,and high steer knuckle. 8 donohoe signature series res shocks 20x12 weld cheyennes, 49" Iroks, 3.5" steel wheel spacers, clocking ring for Transfer case. price tag 15G if not more I had to build my own
shackles front and back, and get driveshafts lengthened re design tranny bar as drive shaft from stock goes above, and had to make new steady bearing mount. here yea go
