I was under my truck to look at something today and noticed some rot. Since everything is caked with snow, it is hard to tell the extent. The truck is a 94 f150 supercab. The metal that is rotted is the part that the body mounts are bolted to just behind the front bumper, below the rad. Because of the snow...pictures would not have helped.
What I am looking to find out is if the metal that the mounts connect to can be replaced(is it bolted in?)??
The truck does not have large amounts of rust and this is the only bad rot that I've found. Never saw it when buying the truck. I will also add that the rot appears to outside of both front mounts but I'm sure the whole section will need to be addressed. The frame is solid with no rot...so I am hoping that I can simply replace a cross member or something of that nature...
Can someone give me some Idea of what I am looking at.
Appreciate any help
Appreciate any help
