Not sure if this is the right place but here goes.
If you wanna disable your Daytime Running Lights heres a quick, but annoying way to do it. Not messing with fuses or wires, all you need is a pair of pliers.
If you look on the Emerg. Brake pedal there should be a small rubber stopper that presses against the E-brake sensor which controls whether the E-brake trouble light is on/off on your dash. Just take off this rubber stopper and thats it. Apparently if the E-brake light is on it disables the DRLs.
I found this out because the little rubber stopper fell off my E-brake pedal and it wont go back on. I had the e-brake checked at Midas and it is NOT engaged, works fine, its just the light is on on the dash. Since this stopper fell out my DRLs are not working. I had the guy at Midas test it and he pressed a screewdriver against the sensor and the DRLs came on.
Kinda freaky but if you can live with your E-brake light on all the time its a quick cheap mod :icon_lol:
