$6000 for this???
" the pics will be in the next email
heres the stats on the car
electric fuel pump
31 spline strange axles
5 lug pro-stars on the car
skinnies on the front
drag shocks
1/4 stick shifter reverse manual valve body
2600 stall converter
full spool rear 4:10 ratio
sub fram connecters
welded in roll cage
the interior is in tact and looks stock
ford motorsports B cam
victor jr intake
holley 4150 carb
hooker headers with dumps at the rear axle
this car is amazingly fast and reliable
the car has barely been driven in the last 5 years.. maybe 300 miles
only a couple of trips to the drag strip
I used to have Nos on the car, and aluminum heads, but with that combination, it was a 10.79 trip at the track and too crazy on the street.. so i went back to cast heads and took the NOS off the car
the car also has the 140 mph speedometer.
a word to you. you will never ever break the tranny or the rear. they are built for an 800 hp car.
the engine is perfect. but i do have to run 93+ ocatane because of the 10 to 1 pistons "
