1 - 8 of 8 Posts
Okay.. another problem popped up on my 01 ford ranger ( 3.0L RWD).
Just a few days ago this started.. my O/D light keeps turning on and the truck shifts a little hard from 1st - 2nd gear.. and my worst concern is the cruise RPM. going 100km/h its at 3000 rpm.. way too high. so trying to pass people on the highway is pretty hard on the engine. pushing the O/D button doesn't do anything at highway speeds.
I recently finished college ( big debt) and got laid off from my job for a while.. so i am trying to read as much as i can and get some help from people online before i go into a shop, and piss my money away.
any help is appreciated.
Thanks.
if the o/d lamp is on/or flashing there is a trans failure,it should have stored codes that will point you in the right direction.
Discussion Starter · #5 ·
Yup the O/D off light is flashing.. but only after a few minutes of driving. After i shut the truck down it wont come on until i drive. i haven't been able to scan it.. looks like i should just take it into a shop.
You might have a solinoid problem, maybe not allowing pressure thru channel inside tranny. this will damage plates so get it seen too quick. Find out what tranny you have? Good luck.
Thank you everyone who messaged me. I checked the fluid level and yes it was way above the checked part of the dip stick so I drained a lot of fluid out. I also replaced the vss in the rear diff. Now all is good, also changed the diff oil & replaced engine oil. This F150 has only 116,+++klms from new, so I'll be driving it a long time. Thanks again.
Wow..congrats on finding a nice survivor with low klms and thanks for. Advice cause i love to tinker but im no mechanic even though i have a proper manual..
1 - 8 of 8 Posts
